Freestyle Another prop recommendation thread... [emoji1304]
Yeah I know they get posted all the time but it’s the last part I need to order for my ski...
Motor setup is going to be
Group K 780 big bore
48 Full Specs
TNT V3 pipe
Total Loss
Head, etc...
Pump is an OEM 155 for now.
So what prop should I run? Model is more important not sure what to look for...and then pitch as well. Can be repitched but I’d like it to be a close starting point. Big hub prop? Etc..never really done any pump work etc. all I know about is hooker 9/15’s for the 144’s.....
Sent from my iPhone using Tapatalk Pro
Big Kahuna
Administrator
Tuscaloosa, AL
48 Full Specs
TNT V3 pipe
Total Loss
Head, etc...
Hooker 10/16.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Big Kahuna
Administrator
Tuscaloosa, AL
Sanoman was chasing this all summer with his ported XS 865. Dont think he ever got satisfied with setup. From what I have been seeing. Taylor Curtis has had great luck setting up Edges with OEM 155's with stock 701's with pipes and heads. (Surf Ski's). I rode one and it was incredible. I feel like there is something about built and ported motors that the OEM 155 does not like. There is a thread about the 155's.
Christian_83
Xscream
Denmark
I had my DASA 850 SS power valve with dual 49 FS, MSD digital TL, PFP exhaust and OEM 155 pump setup with E75 Skat Trak 7/14 thin blade, cut back.
My suggestion would be 6/12 ish. They tune the pump, with exit nozzle diameter, pump cone, impeller spacing and finally prop bending if you need to go high/lower pitch.
