If you don't want to grind off the "ribs", you could create a "foam sandwich"
that covers up to the level of the ribs. Use like marine grade polyurethane
5 or 8 lb. foam..blue stuff..comes in sheets.Cut it in pieces to fill in between the ribs,then Epoxy them in. Use a good bonding filler like (cab-o-sil) to mix with the Epoxy and stick them into place. (use epoxy cause the bottom is SMC, "sheet molded compound" and polyester resin doesn't stick as well).
After that cures block sand it "level" with the ribs....
That foam sands real easy with 36 grit..Fill the excess voids/holes with another
mixture of Epoxy and microballoons. That stuff sands easier too.
Ok.. now lay down your reinforcement layers to pretty things up.....Carbon is stiffest, Kevlar is lighest, Glass is cheapest. Almost anything is good.
Sometimes think "aircraft" when working on these "boats"....
A wall with sheet rock is structurally stronger with one layer on each side vs. two sheets on the same side...But don't let it get wet!
