- Illinois
Ya nobody puts primers on their sleds, unless they are running junk (or an older ski-Doo that came with a primer, but same thing as junk).If you guys think Primers are Voodoo, go tell the Snowmobile crowd.... Finger Throttles, Slide Carbs, are all out all of this world to them.
Primers are one of the best things you can do to make your ski more reliable.
1. If plumped correctly, you can use them to prime the entire fuel system. I've seen people tap into the fuel lines before the selectors and all kinds of crazy stuff. Tee it off right before the carb(s). This way if you switch from Reserve to ON, you can just prime the lines instead of WEARING DOWN A STARTER by cranking for more than 10 seconds... Also helps when you go to start it, and the engine is running on Primer gas. The carbs will have fuel right there at the carb, not sucking it up from the tank. Better PRIME It again!
2. If your carbs are clogged with crap, like he had in this post, the primer will bypass that and get you home maybe. You made the mistake of using a very small(for a weed whacker?) fuel filter. Get a MARINE grade fuel filter with much more capacity. They're $11 at O'Reillys.
3. Chokes are a joke. Putting your hand over the carb(s) gets hard when you have Tornado filters, but I get it you're Goro from Mortal Kombat....four arms!
If your fuel lines are plumbed correctly, your fuel won't run back to the tank, and then you won't need that primer. Heck that primer is probably the reason the fuel is running back to the tank in the first place.
