Custom/Hybrid Answers to some of your questions - truth about light hulls
IceMan
Building a ski in Progress
Technique V.S Power...
The more power you have the less technique you need to do a backflip or other aerial tricks....
The bottom line is .... you can buy a good lightweight hull and put your current setup in it to practice the tricks but after a while you will have to upgrade to a bigger motor if you want to perform the same tricks at a greater degree of height!!
You cannot expect the A/M hull to do everything for you, you will have to get the proper equipment, practice daily and have the balls as well....
Good Luck!!
