Any USA Dealers carry the cool X-2 Bling?
hhh
still have to finish the model and talk an nc operator to run it for me that will be the easy part. im still riding on the weekends and taking small jobs on the side so i can get this sj built so i havent had much down time, but its coming soon and i can get some work done on it.
hhh
looks simple enough
any cost yet?
i was going for simple. i want to make one similar to the pic i posted for a simple bolt and go option and keep the cost at a minimum.
but for the more die hard x2'er im working on something else for the trim......
would any of you all be interested in a bulkhead mounted trim system with almost effortless lever pull?? and will also allow for a smooth dash. this will definitely cost more then the above screen shot, but im dong everything i can to keep production cost low. my scope on the original design was to make a full bolt and go kit, cable, lever, and throw system all for under $200. depending on the intensity of the nc work needed i think i can make this happen. thats another reason for the simplistic design structure. if i can get away from all nc work then i could defiantly keep it in that price range.
thanks for the input guys, i am always looking for feedback
as soon as i get a decent model of the BH trim i will give you guys another image to drool over i promise you guys will like this.
If someone has access to a CNC mill that is your best bet. That way only one program has to be written.
The cable and lever from a BMX shop should be no more than 35-40 max. The big dollars will be in the machine time, programming, and raw alinum cost. If you guys are running salt water, I recommend it gets a clear anodizing too.
My Japan wish list:
Trim Setup
Dash Cover
Rear Tray Step Things
Foot Holds
Keihin Throttle Drum
Hood - wishful thinking
Hull - wishful thinking
Big Bore P/V cylinder - day dreaming about lottery winnings
If you guys go on Motoine's website or Hot Products Japan, there a lot of cool little small parts I could add up to $500 or so that I want. That have the coolest things. Probably because they are not as easily obtained here.
hey guys I'm pretty new to the site and to workin on the skis I've had my x-2 for almost 15 years. I have a guy that makes me backets for my stunt bike and can forsure put out a nice product. I will talk to him and hav him make a post if wants to make some. He does have a cnc.
