Anyone ceramic coat there ski?
If so did you do the hull as well? The turf? Chin pad?
Thank you
I used the Velocity Visions V3 Stealth kit on my XFR and it came out great! I did the upper deck as well as the hull. It makes cleanup after riding way easier, everything just rinses right off. I don't think you can use it on turf or anything porous. Lol It's meant for painted/gel coat and glossy finishes mainly. It works pretty well for stopping bathroom mirrors from fogging up too. Hahah
Make sure you read the instructions and don't skimp on surface prep. You have to remove any and all wax or other coatings from the surface first You should also clay bar everything and buff out any scuffs prior to applying the coating.
Thank you for the tips. My wife and I have both of our car/truck done. I will be having it professionally applied by the company that did the cars.
