Anyone got pics of their MSD TL setups/mounting?
my msd dry box
heres one i made from a dry box from walmart and a old seadoo box and wiring i had
if i could redo it i would just wanted to protect it at the time would now mount on the back in the same location as my oem eletrical box and put the coils and all in it too but i removed my msd and went back to stock for now its plenty fast for the time being but will propablly reinstall it next winter
*** good idea too no matter what box you make or go with through some packs of silca gel from beef jerky in there to help absorb any possible moisture**
FROM MY POSTING*********well finally finished it used a drybox from walmart and a old seadoo electrical box to make the waterproof fittings. then used epoxy to weld it to box ran stainless steel bolts through it for extra security with silcone and bolted msd to bottom of the box with 2 more stainless steel bolts sciliconed also.( Seeing how just 1 water proof gromet is 15$ at the boat store and needed 3 that was just too pricy )then just used the wires from the seadoo worked amazing took out today and when i came home washed it out and then checked it not a single spec of moisture gonna build a bracket to mount box on just wanted to take it to the lake today so zipties and bounge cords had to do.
thanks for the help on the wiring​
ATB
RICKTER XFS 1100CC
granada spain
ATB, what enclosure box are you using? Is that off e bay? Also its really hard to see what type of grommet you running the spark plug wires through. But def one of the best enclosures ive seen yet....
this case is normal house of the outdoor in the garden.here electricity in Spain is purchased in stores electricity and the price is 7 usd.its very hard and have only 4 bought,turn midel and its open for view into
Christian_83
Xscream
Denmark
Im working with a full water proof visual enclosure for the MSD TL allso, and should easy house ATP TL or "stock" style ignition, i would house ALL electronics, brain, coil(s) starter realy and wires.
This box, has a little better room, not much, about 1 cm higher, making to best box for the brain to stand up right. It has a flip style clear lid, and is water proof. This is the cheapest box.
Grommets with 4 wire out puts, for stator cable ect.
This box is the "nicest" and allso more expensive, im working with placement of brain, the last picture would utilizie the space best, i can fit like that.
onedumbtrucker
Now with 20% more pulp.
London, ON
Hammond and Hoffman enclosures websites both have dimensional drawings of all their enclosures. Not sure what the part numbers people here are using but you should be able to find something that works for you on those sites.
I bought my box from wolf automation online: Part #111-008, 2518 Series, 254x180mm. I also bought the 1/2" gland nuts I used off of their website.
