Anyone know what kind of pipe this is?
37
Precipitation Hardened
Indy
It's not one of my pipes.
But looking at it. It' appears to be setup for factory B manifold head pipe setup.
Could fit kawi or Yamaha looking at the shape
That pipe is TNT limited chamber spec assembled to go forward and be end bleed not center bleed
Wait, so this is or isn't your chamber? On page 2 of this thread you said it's not yours.
Looking at the photos and how it's laid out, I suspect it's not yours. Aside from what looks like enlarged belly dimensions, the water inlet for the stinger is in the wrong spot. The coupler at the stinger wouldn't last long as shown.
tntsuperjet
Georgetown ca
If you see a Vw bug that someone cut up and turned into a baja bug.
Can you tell it's a bug from a picture.
You have to remember I see ever part of my chambers in pieces thousands of times
They get laid out in so many different ways.
Besides inbuilt several chambers similar to that over the years for blaster I built for customers.
That's just not one that I welded up.
