Anyone ohm out their plugs?
Crab
thanks darin...noswad!
Seattle
Originally Posted by Watcon
Knock the plug gap to .015" and see if the misfire goes away.
Did you try this yet?
It ran ok today, no misfire now. However my compression is down from last season and I may throw the fresh topend on there. 153/158 62T cylinder 701 with 35cc domes.
I don't think there's anything wrong with those numbers.
Retest your compression with a fully charged batter, known good starter (IMPORTANT!), throttle wide open, and a plug in the other hole.
Crab
Seattle
Did all that and a new Liesle guage from Napa. Just no bottom end now. I did have a problem today with no start, turns out the negative cable was not working properly, made a jumper to the cases with some #12 wire and it ran fine the rest of the day.
Crab i had the same issue in Pismo with no bottom end and it turned out to be a leaking oring on the front piston. Is your plug wet with water when it is missing?
Crab
Seattle
They seem to look fine, no evidence of water or steam from what I can see. I'm going to pull the carbs and check them first, then the head if needed. I did use 1211 when it went on.
Mine didn't steam and if you checked the plugs after running for a while it was dry. But if you check with out getting into the RPMs to heat the plugs up it was wet.
On a side note my engine wont be done for this weekend the pistons are on back order.
Alaska
Crab, I just ohm'ed out 2 new BR8ES's. Using a Fluke meter I got 4.96 Kilo- Ohms (4,960) and 5.01 K-Ohms on the second. They are solid tops. Something dont jive with your readings. Try a different meter.
You might want to wring out your coil as well, especially your secondary.
Oz
