Super Jet Anyone running a NYNJA chamber in a SN?
tor*p*do
Squarenose FTW
NW NC
How did it fit?
What did you do for discharge plumbing to the waterbox?
How do you like it and does it hit better than a b-pipe?
thanks!!!!
OCD Solutions
Rentz, GA
Search TNT Chamber, it's the same pipe and I know there were several threads on it. Fitment answers will be the same. The NYNJA unit is the superstock version if that matters.
#ZERO
Beach Bum
Florida - U.S.A.
The TNT superstock chamber requires the compression to be lower than 180-psi and works well with engines that have higher port timing.
Have you tried the Blaster Mod chamber yet; they're a more readily available.
cattledog
EH TEAM RACING
toronto canada
dont bother just use a normal b pipe chamber, i had a mod blaster chamber in my sn and a limted chamber not much difference i have the real tnt in my sxr, there chamber is way overpriced
