If you're using the timing curve selector switch make sure it's open. If you're using the 3 position switch set it in the middle. The edit cable uses the same two wires that the switch uses.
Unplug all the USB devices you can.
If that does not work, check if the driver where installed.
Press Start->Setting->Control Pannel->System->Device Manager
Go to "Ports", expand it and note how many devices. Plug in the cable and then look and see if a device was added. If a device was added and has a yellow question mark '?" you need to install the driver. If the device is called USB Serial Port with out a question mark you should be ok.
I could try to explain install driver however see if any of this help.
