parrdaddy
No he will not!
- always be a TEXAN!
I recently had a run-in with some MSD enhancers, the usual firing when you let off the green button thing. OK fine, I put the stock CDI back in and it ran. I went through 3 MSDs in a short time so I was a little pissed, until my ski died with the stock CDI. I ended up pulling the stator to find the real problem, a broken wire to the trigger pickup. I tried a new stator, and what do you know, my enhancers started working again. I think the stock CDI is more resilliant to higher resistances than the MSD units are, which is why it kept running on the stocker until the wire finally broke completely.
So anyway, I thought I probably had a rare situation at my hands so I didn't think much of it, until Daytona. I helped Joe Eckert on Saturday diagnose his no-fire problems..........same exact problem. Then Donald Smith's ski wasn't running on the MSD but it did when they switched to the stocker, they pulled off the stator.......same exact problem.
I'm not saying this is the problem everytime, but it seems to be more common than I would have guessed. So, if your MSD Enhancer is broken, it may be worth your while to ohm out your trigger pickup (red/white wire to ground) in the box. It should be 12.6 to 15.4 ohms for a RN SJ according to Yamaha. The wire seems to break right after it comes through the grommet on the stator, before it enters the protective sleeve under the pickup itself.
Just an FYI
Just an FYI
