atp flame total loss
Hi all, since ATP is closing, I am curious if anyone that uses their total loss system has any problem with any of the components, such as the cdi or pick up coil, flywheel, etc. How can they get the replacement??
Do they need to switch entirely to other system such msd or go oem?
The reason I ask is that my sj had no spark yesterday and I checked everything and changed the new ignition coil except I haven't pulled out the flywheel to check the pick up coil yet which looks like something (may be the wire from the stator plate came loose??)
anyway, I wanna prepare if anything is completely broken should I msd tl or oem (I already have msd brain unit and have to buy the rest)
Quinc
Buy a Superjet
California
I dont think you can get msd anymore either. Your best bet is Zeeltronic. Do a search and you will find a ton of info about it.
hi thanks for your answer. if I understand correctly, zeeltronic means that I will have to find oem system and use zeeltronic cdi?
Quinc
Buy a Superjet
California
Correct. You can also run it as total loss and knock out the flywheel magnets etc for a lightweight flywheel.
