Freakrider
X247
- Tampa Bay area
Let's hear some reviews guys...how's it performing for you and on what motor ? Reliability ? How's it compare to MSD TL ?
What motor are you running and how's the performance of the TS2 ? Did upgrade from a charging ignition and feel a major difference ?Also been running it all year with zero issues. I haven't experienced any timing issues or needing to disconnect anything prior to charge. Did ATP instruct that @CARBONX2? Art programmed the curve for my engine and didn't say anything about it....just curious.
Sent from my SM-N900V using Tapatalk
I would imagine so but I couldn't tell you for sure. He sent his brain to Art (I believe) or at least got the switch chart from him for his setup and I purchased my TL through Art so he put the curve on it and sent it with my engine. I would think same engines, pipes, carbs, compression, porting ect. that the curves would be pretty close if not identical (or as close as they can be). I'm just assuming this though. It could be possible that one needed a different adjustment to exhibit the same characteristics as the other or vise versa. I do know even though my TS2 can be set up with the twin spark Art preferred the single hottest spark like the old flame system. He may have since changed his opinion but at the time there wasn't a power increase or enough evidence to justify programming it that way.^^^^That's kinda what I've been looking for^^^ Next question would be, were you two running similar timing curves? All things being equal is there a noticeable performance advantage of one over the other?
http://www.x-h2o.com/index.php?threads/atp-flame-superlight-flywheel.144720/
surprised no one has mentioned this thread,where flywheels,starters and bendix where all gettin chewed to bits by the flame?
