Other Autoclave
I think autoclaving jet ski parts /hull is way overkill. A well built infused hull would be enough.
We autoclave very few parts for our boats mainly rudders/daggerfoils.
Think the same. A well done infusion is the best way for skihulls. But most people cant handle it and and a failed infusion is a nightmare........
One shot infusion with 5/8mm core out of mould. No more finishing needed.
88kawi5fiddy
pew pew lazers!
So Utah
lots of things in life aren't needed. but lighter+faster+stronger = better. if someone has the money to spend on an autoclave and hull and is happy with 5 lbs less material and a stronger hull let them do it and give them applause
Whale
X
New Zealand
Yer sure thing if your got the money no harm in spending it. There are a few things to consider befor just chucking a part in an autoclave like your mould will is survive the autoclave?
Do you use a clear gelcoat in the mold first? Do you use Pva or some other mold skin?
Yes, its a special clearcoat. You can put it in mould an it goes in a good conection to the resin weeks later wuthout sanding. Work with no pvc relies . Only waxing the mold with special wax for the special clearcoat.
Vumad
Super Hero, with a cape!
St. Pete, FL
Cool, thanks. Workin my way to the kind of work you do. Don't want to bother you too much because I'm sure layup, resin choices, fiber choices, etc, are a little bit of a trade secret.
