Hey guys. I know this topic has many posts, however, I couldn't find one that answers my questions. I'm hoping someone has had a similar experience and can provide some insight.
I have a 1995 SN (701). As far as the engine goes, it is all stock and very low hours. I just installed a B-pipe (limited) and set it up to the Factory Pipe specs -
Main Jet : 145
Pilot Jet : 120
High speed screw : 1 1/2 turns out from closed
Low speed screw : 2 1/2 turns out from closed
Needle & Seat : Stock
Spring : 95 gram
It ran pretty decent during my initial test ride but was running rich. I tied it to the trailer and dialed in the low jet. The highest rpm at idle was at about 1 1/2 turns out (not 2 1/2 as FP suggests). The pipe adds noticeable power, however, I am still running very rich. Turning the low screw in more, doesn't seem to help. The ski ran flawlessly before adding the pipe. The ski is very rideable, just not quite right. The exhaust exit shows that it is rich since it is all black on the back of the ski.
Mid to full throttle it pulls hard. When running about 1/4 - 1/3 throttle, it seems to kind of gurgle. However, doesn't hesitate or bog when I snap the throttle. Just not as snappy as it should be. It is particularly noticeable when setting up to jump a wave.
Should I be dropping down a size on my pilot jet? I would have thought that the jet sizes would be right on since I have a stock machine and FP provides jetting specs for a stock ski.
BTW, the pipe screws are set up with top and mid closed and bottom open 1/2 turn - FP recommended settings.
THANKS
Main Jet : 145
Pilot Jet : 120
Spring : 95 gram
THANKS
