Should be able to find one use for about $150. FFP also sells them new for the big bucks. If you buy used, ask what the outlet dia is and avoid the older ones that are in the 42mm range which led to issues with detonation. They newer ones are 47mm or so and some hog them out even bigger.
or buy an old one...cheap.. and hog it out yourself. if you know how to do heli-coils that also gives you an advantage. i got my stripped out mani for 60 bucks.
3 heli-coils, a bit of porting and some powdercoat and it looks better then new!
