b-pipe puttin hole in my hull?
I have done exactly the same thing..I wondered where the water was coming in..
Lift the waterbox and place some hydro turf against the hull and the petrol tank..
Also helpful hint..buy gaskets and remove the bolts from the header pipe to get chamber out don't bother about removing the tank etc
easyrhino
needs more cowbell.
The river
I raised the water box by shimming it with turf, at least it will rub a different area. Make sure the fuel tank it all the way to the right side to make more room.
Note: if the waterbox it raised, it could come in contact with the fuel tanks fill hose. I put some turf between the two and placed some turf between the tank and waterbox
Is there a thread on stinger coupler mods and/or options?
