B pipe question
he said he JUST bought it....
the stock head is fine as in safty if your thinking about the cyl cracking. Your not running a dry pipe so your RPMS wont be really high so no need for a girdled. But would it be a good idea down the road YES. Also you wont have great bottem end with out the comp. If money is the issue then b-pipe for now and then do the head if money isn't then do both now
Gainera2582
Power and Agility
Ive ran the bpipe with stock head and an msd ignition(more important than the head imo) and it hits really hard at 150psi!!!!!
Ill be bumping my compression up next week to 170psi with an ada girdled head, so I will let you know how it goes!!!!!!
I know you're a big fan of the enhancer and I agree they are a good mod, but they are nothing like increasing your compression. A girdled head would be higher on my list than an enhancer for sure(as long as you had a modified stock cdi).
I guarantee you are going to be impressed with the compression increase. Go up to 185 though. You'll be fine running on pump gas as long as you don't run WOT all the time and the boat is jetted properly. Hell I know Chuckie sets up some of his Team Scream motors at 200psi and they run pump gas all day long. I guess it's all in how you set it up. I think you'd be safe going with 185psi though. just my opinion and my knowledge is limited to what I've heard from talking to others.
got ya Thank you. And as far as jetting goes just put new plugs in and take you ski for a spin and then check out the plugs to see if you should go more lean or more rich?
Waste Land
Non Multa Sed Multum
Florence, AL
Actually, using older plugs with carbon is a better choice because they will turn easier then having to wait for new plugs to darken.
If your running stock setup with b pipe FP has the jettings required on their site
SJ Thumpa
SJ THUMPA
One of my ski's runs stock head and B pipe. The other Riva head and dry pipe (none girdled) IMO, Run it, tune it and change it when (and if) you want to.
Marshj
DarkHorse
Ann Arbor
I run a b-pipe, stock milled head, and MSD...its all you need to learn a LOT..even for flatwater...if my cycl cracks...bummers
SJ Thumpa
SJ THUMPA
Hi, Wasteland.
I wondered whether that was possible.
Thanks for posting that. So if I run over carboned (dark) plugs and wish to retune, can I regain a true reading by running those over-carboned plugs for a while and hopefully getting them to read right (a lighter color) by minor tuning?
Am I right?
teton
tetongravity.com
Washington DC
Why use the stock pipe, if you already have the B-pipe???
The stock cylinder head is ok, but a girdled head is a good upgrade. It's a must if you are going to have the cylinder ported.
why is it necessary to run a girdled head with a ported cylinder?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Ported cylinders (IF done correctly) makes more horsepower, this makes more combustion pressure then the cylinder block are more prone to crack at the base from the extra load.
TheLostOtter
I'm lost
US
Hi, Wasteland.
Am I right?
You should be fine as long as they are not fouled plugs. I just retuned my ski the other day with plugs that were over a year old. They had a little carbon buildup before the tuning. After all the WOT and adjusting the high speed screw, I got them looking great, with little to no carbon on them anymore.
snowxr
V watch your daughters V
Waterford, MI
The ported cylinders have material removed in ares that leave it prone to breakage. Most builders also suggest higher compression, which puts more stress on the cylinder, and leads to either cracking the base of the cylinder where the studs are, OR cracking about half way up the cylinder where the porting has thinned the casting.
