does anyone have a diagram of how to run the water lines on the B pipe?
drawn diagram..
Actually that is wrong if you decide to run a FCV. If you run a FCV then the straight end of the T should go to the FCV while the t end of the T goes to the bypass.:biggthumpup:
how come i can only find 2 water screws on the head pipe for tuning on my pipe? did i get a older style or somehing?
Its not wrong at all. Its preference. FCV is a flow control valve
