- Amherst NH
This guy seems to be getting it to work. It looks like you have the 650 exhaust manifold.
http://www.pwctoday.com/showthread.php?t=149098&page=10
That's the blaster mod pipe sah225 is using not the 750 limited.
Here's the deal...
The mod pipe fits fine pictured on the yellow ski.
The blue exhaust manifold is the one for the limited setup but has too much indexing and the head pipe hits the hull.
The stock manifold leaves a gap.
If you look at the 3rd pic with the WC manifold you can see the chamber hitting the lord mount.
What would happen performance wise if you made some sort of adapter to fill that gap? Couldn't you make a longer coupler out of marine exhaust hose and mount the pipe properly to keep it from popping off that way you shouldn't need to mold the tank?
You would definitely change the performance characteristics of the pipe.......probably for the worst.
Again, cut the lord mount off the exhaust manifold. This will allow the chamber to hug the engine and line up with head pipe. When I put the Blaster Mod pipe on without the cut lord mount the 3rd pic was exactly how mine lined up.
My concern is that you had to mold a SJ tank which doesn't sit as close the the motor as the stock X2 tank does.
eitherway, I think I found a blaster limited chamber... Now to find a headpipe.
I took a look at how the B-pipe will fit into the hull. The B-pipe will not fit into the X2 hull with a factory manifold. Tom and I do think it will fit in with a modified westcoast or stock manifold. The westcoast has a mounting spot on the manifold that interfeared with the alignment of the Kawi limited chamber, but we believe that if this mounting part is ground off, everything will fit. The kawi limited chamber should fit in with the stock fuel tank. It appears to have the clearance. However... I will have to make a custom mounting bracket for the chamber, because the mounting bracket provided with the limited chamber would force the chamber to align with the front of the cylinder, and that just aint gonna happen.
