I have an old B pipe header that somebody welded the center screw hole closed, got it cheap, thinking about modifying.
I'm going to be using it on a motor that I want to be more mid to high powerband, and since the lower screw is so hard to access while installed, I was thinking about welding that solid as well, then putting a spray bar down there, with a jet in the line feeding that spray bar located in some convenient location, so I can easily tune the water going into that location. Very likely I'd have top screw closed at all times, middle screw effectively closed (it's welded solid) then just use the easily accessible jet for the spray bar in the lower location for my tuning.
I've never been a big fan of the screws in the B pipe.
Wondering if anybody has done something like that before?
