Standard length for my old -4.3 BAAnyone know what length shaft the BA uses? I’m assuming standard SJ length?
I forgot to measure before sending it out for paint and I’d like to get one ordered now so I can have it ready to rock when the ski comes back. I’ll be using a skat 155 mag setback but I’m not sure with skat if the shaft will work at roughly the same length as oem.
Thanks man!My Badass has a custom .75” shorter pre08 driveshaft for some reason . I fitted a 148 pump shoe/sb pump in mine and the intake grate hangs way low . The effort you went to make the 155 pump fit is extensive I’m sure I hope it works well for your ski.
I believe it’s just the way the badass was designed. Everything is as low and compact as possible including the engine which is like a 1/4” from the botton of the hull giving it a very low center of gravity which makes the handling so special IMO. When you chop the throttle on mine after a high speed run it’s like putting on the brakes lol. The hookup is amazing especially in white water surf conditions it’s badass . I’m sure yours will be a beast with that much power .Thanks man!
Yeah, not sure why the intake grates all seem to have this common issue. I figured I was missing something but after speaking to 3-4 people that had the same issue I’m not so sure.
We’ll see how it turns out hopefully it will be done intime for the blue marsh ride on the 23rd!
It was there for different seasons so I’m not sure what the average temp was but the water was 30’ deep for the first 16 months and abiut 19’ for the last 2. I’d say 40-50* maybe?How cold is the water where it was setting on the bottom
Moved@Big Kahuna
Can I get this thread moved over to the my skis/buildup section? Should’ve put it there in the first place my bad !
Not so bad for 18 months under water though huh?
Thanks! I wish the cyls polished out better but I didn’t want to spend 3 years sanding with the season startingSo what you're saying is, you really can polish a turd after all? Haha
Cleaned up well!
