Other Back on the Big Bore Bandwagon!
BruceSki
Formerly Motoman25
Long Island
Well after riding half this season on an old, worn out, beat 61X/61X 701 with a pipe, head, lightened stock flywheel, msd enhancer and flow control valve I'm finally back on a bigger motor.
I would say the small motor helped my riding a little, since I didn't have much power I had to go back to technique. We have been lucky this season and had 4 footers most of the time too which helps as well. I have learned to backflip with this little 61X though. It doesn't take much power in the surf just the balls to launch off a head high wave and chuck it backwards.
The motor with the green head is a jetworks 771 with blackjack 44's and case porting. It went into my fixed steer.
The other motor is a new set of cases and billet cylinder from xscream @846cc's. It will be going into my new square build.
Anyhow, I'd like to give a big thanks to the people who have helped me on the way:
Team Scream
Jetworks
Steve PWC
Jetmaniac
Ryan
Timmy
Tow Ropes
BruceSki
Formerly Motoman25
Long Island
771 runs pretty damn good.
Took it out yesterday and dialed in the high and low screws. Ran a full tank of gas through it too. After getting the tuning dialed the motor feels great, however: I need to work on pump tuning because its cavitating pretty bad.
Going to take the stubby cone out and go back to a stocker for now and test another prop. I think the answer is going to be a TBM pump cone or solas mag pump though. $$$$$
Eww, TBM! Solas forsure. Worth the couple extra bucks.
I love the difference in hookup in the surf. Flat water, I felt it but not as much.
BruceSki
Formerly Motoman25
Long Island
I used to run a tbm come and a big hub prop in my old setup. It works well for what it is and is easier and cheaper to install than stripping my pump to build a mag out of it.
