- grants pass, oregon
I have a 94 750 and it started to run like crap, like it was runing on one cylinder. so i pulled the motor to replace the crank seals and found out the carb gaskets were leaking and the pipe gasket was leaking so i got that all fixed thinking it would run, so i also got a bilge. but when i put it all togather it started back firing realy bad, so i pulled the coil apart and it was all bad so i bought a msd one and put that in, it still back fired. so i replaced the pipe coupler thinking it wasint sealing wrong but still was doing it. i have i msd ignition inhanser as well have had it for 2 years or so. i im thinking about buying another one but i dont know if its that or the stater.I also have a timing advance plate if that helps.
let me know wat you guys think
