Backie Chan 850 BB need help bad....
Well no jetting ever worked and finally it ran worse and worse till I took it out and it wouldn't start. It will spark on the initial push of the button and if you keep cranking it, it will randomly spark.
Hx3
New coil
Clean Oe 62t stator
Where is a good place to start. Is it just this hx3 epic ignition
Stockton
I have a good working set up and HX3 in my ski. If it would help you Id be willing to install your HX3 in my ski and see if your issues transfer to my ski. It might help isolate the issue and give you direction.
That's a possibility I will swap out for a stock Cdi hopefully just get to ride the thing I contacted air time to see what's up. Maybe get it swapped for a new one idk
Stockton
Yes that's an option too. Seems simpler but won't reveal if the issue is in the electric side of the set up or not, a stock CDi or an MSD enhancer is much more forgiving.
My MSD worked with my TBM flywheel but as soon as I installed the HX3 I had issues so that told me it must be the HX3 since ski was fine prior but after 2 months of being down that want the case, it was that flywheel. Chris at Airtime diag this.....
Are you the original purchaser within the 90 day exchange period?
I guess installing a stock CDi would help some though, if the issue still remains you got other issues too, if it does work you could ride but you still won't know if it's the HX3 or your set up.
If a stock CDi works in your ski and your HX3 works in my ski what's that reveal?
Edit: ^^ this is more of an example of what I'am talking about rather than a question
swapmeet
Brotastic
Arlington TX
So I'll throw out a "hot sports opinion" but if you have a lower pitched prop laying around, try that.
I had a similar problem on a ski, it would bog bog bog until the pump cavitated enough for the impeller to let the motor wind up, then "whaaaaaa!!!!" The damn thing would launch.
I could be completely wrong, but that's the first thing I thought of when I read the symptoms.
Sucks you're having so much trouble with your motor though.
Hx3 sent in for further testing. But the "jetting" issue transferred to my stock ski when I put the hx3 in it. So yeah it was the ignition.
