Freestyle Backie-Chan Rebuild
Yami-Rider
TigerCraft FV-PRO
Texoma
Helping a buddy bring a backie chan back to life. I've been around this ski since it was new, it has thin glass issues, broke within the first week of flips. Now 3 owners later my friend owns it and is time to fix it right.
Engine bay was a mess
We were able to start by just pullin/ripping glass out by hand.
Between a sandblaster and a couple different sanders, we got the engine bay all cleaned up and back to original fiberglass (forgot photo)
Just got in the 21 oz 8-Harness s-2 fiberglass roll :)
Tied in the bulkhead to the bottom, I've seen too many break in this area. Pure 1" thick resin was used to glue in the bulkhead, which creates a weak point, now better then new.
Patched all the cracks and sanded, to be ready for vaccum bagging
VXSXH20
Sionis Industries
Mid-Atlantic
maybe your buddy can reach out to the manufacturer and explain what is....oh wait...
-man you make this stuff look so easy. Subbed for another chan rehabilitation -Cheers
Yami-Rider
TigerCraft FV-PRO
Texoma
Only been about 20 days since last update...slacking..I know lol..
Cleaned and filled these big holes in the motor mounts with 2 part foam.
I let beau have fun with prepping/grinding everything
Just a bunch of vac bagging, once you seen one you have seen them all, so i didnt take a pic every time. I vac bagged the entire engine bay. The hull is solid as a rock now.
Perfection :)
Wrappy Chan... I think we did ok for our first time.
Engine bay is complete!...well minus drilling some holes..
Had to get rid of the ugly paint..
Before
After
Time for turf then assembly!
Yami-Rider
TigerCraft FV-PRO
Texoma
Mostly bare hull started out at 76lbs, now 95lbs, not too bad considering I added 180oz layup to the bottom and heavy layup threw out. Hull will see ocean and big yacht wave use.
New stainless steel bow eye, the original one was a flimsy steel eye.
All the incerts found/drilled
Pole area after a little filler and sanded flat
