Any one have any issues with bad threads on ada engine side couplers for Yamahas?I had one that spun on to an adr crank ok but wouldn't spin onto two different oem crank ends. Tried some oem couplers to make sure it wasn't the cranks and they went on smooth. Found another Ada coupler in the shop and it spun on the oem crank fine, ordered another set of ada couplers for the other motor and same thing, crank side goes half a turn and locks up. So 2 of the 3 ada engine couplers I have don't work. Any one else have this issue?
