Custom/Hybrid Ballistic evo 12 cell alternative?
sharkcus
Breakin' the atmosphere.
Strongsville, OH
So it looks like Ballistic has shut their doors. The largest battery I can fit in my tray is 5" x 4.5" x whatever high. I am left with two options, that I know of. (not moving tray)
1. https://www.amazon.com/FirePower-Fe...ords=490-2501&qid=1553966148&s=gateway&sr=8-1
People have used it and even with bilge pump, it's been okay. But 150CCA is still 150CCA.
It's also $75
2. The EVO2 104-013 which is 4.5(L) x 3.5(w) and is 240CCA.
https://www.millennium-tech.net/category.php?cPath=130_131
$230.
I would buy a ballistic battery, but the company is gone and nobody is going to honor a warranty. Have you guys heard of any other battery that will fit in my 5"x 4.5" hole? heh....
I have had a AutoCraft Lithium Power Sport battery from advance auto. I used a 20%off coupon code and the warranty is a year. Just like being about to return it locally if needed. I'm going on year 3. Might want to look at them also
A few of us guys in Tampa are using these with success, after riding for the day it still shows 13.20 with the LFP-4 on TL. Are you running the larger LFP-7 with the 4 terminals? 3 yrs and still good on TL or oem charging system?
I'm using the OEM charging stuff. Unless I leave the bilge pump on when hanging out to long,. But the time I did do that I jumped it and was good to go the rest of the day. Then pulled it that night to charge it over night. I'm pretty sure it's a LFP-4
3 yrs on a Lithium battery running on a charging system impressive considering past posts on here from what I've seen !
