FX-1 Bendix and flywheel cover options?
My bendix is slowly going out and while it seems to have some life left in it Id rather have a bendix that spins up every time instead of 80%.
Are there many options that arent terribly expensive? Last I looked a new OEM bendix was pretty high priced. Should I try and "refurbish" mine a bit?
Also are there any relatively cheap flywheel covers that use reusable o-rings or gaskets? Ive had to take mine off a couple times and the gasket gets pretty annoying to work with. Im probably going to have the cover off one or two more times with the bendix issues and maybe a lighter flywheel soon.
I dont really have a budget, but Im trying to save up for a B-pipe this year so the more I spend the less likely that is.
I bought a brand NEW OEM Bendix from JetManiac. He had a blow out some for a fraction of the OEM price. Im not sure if the deal still applies, it's worth contacting him and seeing. I too had similar issues and replaced mine when I replaced the starter. I've bought uses ones before and they are hit or miss. I didn't want to risk it and go though all the trouble of removing everything to find it was a bad unit.
Not sure about the o-ring flywheel cover, not any that I know of.
I saw that JetManiac was selling used and tested bendixs but I didnt see that he had new ones. Ill have to hit him up soon and find out.
I believe Cold Fusion sells a billet cover that uses a reusable oring, I havent looked into it much though. I wasnt sure if there was an already popular option of if its not a very popular option
wsuwrhr
Purveyor of the Biggest Brapp
Yep, I do a couple versions of billet F/W covers with orings for the Yamahas and Kawis.
I have a Lexan window available as well.
Thanks for the mention Burton
Uh, no offense but you suck.......hahah
brians flywheel covers are amazing. I didn't even know he had a website and still bought a couple and am about to order another here soon. Basically look at his avatar and it does no justice to seeing it in person. Order it now...Done!
What I meant about the website sucking is that I cant seem to find info on the products. I see a few pics but nothing on pricing, availability, or ordering.
3 of the 4 links go to the same page.
JetManiac
Stoked
orlando
JetManiac has oringed flywheel covers from SB products, Cold Fusion, and Dasa in stock.
Just PM with your needs.
wsuwrhr
Uh, no offense but your website sucks. Where can I get some more info on the FW covers?
Website is sh yt no doubt, working on that now, sorry. You could use a teaspoon of sugar with your comments though, but I understand.
There is better info on the FB page as well as several pictures.
Brian
