Over the winter I put on a R@D exhaust,works extended ride plate,r@d scoop grate,wet wolf pump cone, bored the exit nozzle out, single 44sbn mikuni carb, prok air filter. What should be my next purchase.? I thought with the sxi you didnt want to advance the timing anymore than it all ready is. Is this correct? If not should that be the next purchase?
I would like to get a R@D head or ada head, lighten the flywheel, rebuild the top end, Some sort of impellar. What size impellar would I need? What order would I want to do these mods? Any help would be appreciated.
