- United States
Hey guess looking for suggestions on batteries for a non charging fly wheel setup should I break the bank or is it not worth it?
Alright, if I get one of those gel Cell batteries do you still recommend siliconing it?I use an AG and so far so good. What ever battery you go with seal the seams and terminals with silicone and if you can mount it above the water line.
What’s your run time on a single charge roughly?Anything other then lead acid you want to keep dry.
Do you know any specific differences between the etx besides the increased a/h per pound? A little Google searching and all I can find is that they don't have solid terminalsDeka Power Sports - Made in the USA - ETZ14S sealed AGM battery. Lighter than 14 size battery but packs 210 cca's and 11.2 amp/hr inside a smaller case that of a Deka9. Avg 79.00 price range. Amps per hour are going to tell you how long battery will last on total loss.
It's considered extended life with more plates inside battery. 210 cca's vs 120 on the etx9 and they're the same size. It was recommended by a local battery shop.Do you know any specific differences between the etx besides the increased a/h per pound? A little Google searching and all I can find is that they don't have solid terminals
I don't think that is correct. The number of plates determines the voltage and typically each plate is 2V so if you added more plates you would actually be increasing the voltage of the battery.It's considered extended life with more plates inside battery. 210 cca's vs 120 on the etx9 and they're the same size. It was recommended by a local battery shop.
Maybe it's the size of the plates that determines the CCA?
Each cell is 2.1 volts, 6 cells equals 12.6 volts but each cell has a number of plates. Here's the explanation by an electrical engineer
"Increasing plate number per cell gives more output current. CCA value on the battery.
Decreasing plate number usually allows them to be thicker and therefore more resistant to wear due to deep discharge. Deep Cycle Batteries."
I got mine off Amazon for 79$ a couple weeks agoStill able to find these anywhere for $79.00 or has the price shot up pretty much everywhere?
That's a very strong battery 18 amps/hr but it saysCheck out the dimensions on the Yuasa YTX20HL-BS as it is sealed, 310 CCA and $79 on Amazon
