Did you do the kawi pump mod then switch to the 144 solas???? If so how big a difference??
Yes i've done the kawi pump mod en then switch to the 144 with solas mag.
I can compare egal because a lot of another things have been done in the same time .
the kawi pump was with the TBM super cone ( great hook up improvement with a C75 skat prop)
Now with the 144 pump i've a full intake from a SJ aka intake grate , pump tunnel and drive shaft ( pump is setback 2 inch) so the comparaison is not fair...
Kawi pump mod is cheap except if you want a good prop . and doesn't involve extensive resin work.
kawi pump need to be moded if you want a full sealed bearing pump (mine need it sooo bad)
liner isn't cheap to replace ... i ride in sea so this is a big issue.
Sj pump can be full custom :
Solas mag , trim , plastic liner for the wear ring . setback pump is easy with sj shaft.
Plate is an issue with sj pump but tom21 parts will make your life easier .
I've done the two conversion and i didn't regret the time involved in the SJ swap .
