- South Florida
Recently had to get a freshwater prop cut off a driveshaft because of a very small area on one thread galling. Saved the driveshaft luckily but the prop was a goner. I used tons of antiseize on it before installing it to no avail. I heard an idea of using threadlocker on it next time because it "seals" the threads better. Following that same logic I thought that case sealant like hondabond would work the same way.
What do you think? Favorite methods? What has failed? What worked great?
