- Anchor Bay, MI
What about a Coffman half pipe. I heard they're the best you can get for tourqe
Sent from my LG-LS970 using Tapatalk
Do you have a picture or something of the dry mod?Half Pipes work great for your set up... The drier the better. Best Bang for your buck is the Stock Breadbox with the dry out mod. On the front inside of the box is a fitting. Remove fitting and put on an brass outlet - run to a pisser. Ski will ride a lot crisper...
No everything is stock straight from the factory. I'm getting port work also. What are the gains on that aloneIs the crank new?
If you're going to port and put a high compression head you have a good chance to tear that stock crank up. Find a good 440 crank they're much stronger. When you ask what kind of number should you expect.. Compression? HP? Top speed?
Sweet thanks! Is a pjs 17 pitch impeller a little too much? I don't know a lot about the pumps and how they work on this thingDepends on altitude and many other things. Compression is dependent on your domes on your head. You can read them off and we can see what cc domes they are. HP and top speed will also be dependent on your impeller and what kind of port you have done. Just gps it when you get it running.
Thanks man! I honestly don't know what to expect out of this. But screw it. No one's gonna know until I try17 is pretty steep. Can hurt to see how you like it. Keep a 16 or 15.5 skat on the shelf in case you don't
