Best place to buy fuel lines and fuel selector valve?
Had some issues this weekend with starting the B1 and believe the problem is in the selector valve. Got it running thanks to Quinc's help with running the res line directly to the carb but now think its just best to replace all the lines (believe they are original ones) and valve.
Any suggestions on some good lines for a reasonable price? Anyone got a fuel selector valve laying around?
Thanks,
You can find Tygon fuel line locally at an auto or powersports store. Or get Jetmaniac/Thrust OEM equivalent line.
Ditch the selector, most others will agree.
Replace the filter/filters as well.
Thanks am. I will check out the local auto store for the Tygon lines as well as pull up Jetmaniacs parts. On the selector, if I was planning on keeping the ski I would just bypass it but I will probably try and sale it next summer and upgrade. If a newbie happens to be interested in it, I think the fuel selector not working for them would be a big negative for the ski.....thats the only reason I would like to go ahead and replace you know...
