Best place to put a bilge pump?
Forward, get one of the brackets that uses the mid shaft housing bolts & it sits perfectly:
https://www.ebay.com/itm/Yamaha-701...ash=item237a5dc2b3:g:XFMAAOSwzgRWv8eB&vxp=mtr
I ran the hose thru the firewall & put the outlet back by the boarding handles, gives you the room to put an air gap in it.
A great tip I read somewhere - once you put the basket in the bracket then the pump in the basket, circle a zip tie under the clips & it will lock them so the pump can never jump out on a hard landing.
LB
Will those brackets work with the new Rule 25DA pump? I just noticed some people put them in front of the firewall and some put them behind it. Didn't know what's best.
