ANy suggestions on where I should go to purchase new Side rails. The oem rails are expensive - $200 for one side. Any aftermarket products you guy can recommend. I would like to order today.
What I mean but he side rails are the padded rail caps on the sides of the tray. They are molded rubber that are held on by screws and rivets. About 3 feet long and shaped a bit like and open "S".
Oh, those. I believe OEM is the only padded one piece replacement. Most people will buy some 1" hydroturf pad and pad/turf their own rail caps. Much cheaper option than OEM.
Blowsion does offer new composite rail caps, but they are spendy, plus you still need to turf them.
I have them on mine, only because it came on it when I bought. It does clean it up some, but if I were starting from scratch, I would be going pad/turf.
Hopefully someone will post a pic of their turfed rail caps so you can get an idea of how they look.
Just done the same with mine as when I removed the rail caps during my strip down they broke. Filled holes, glassed the ridges smooth and will be fitting undermpad before turfing up and over the top.
