Best Steering Setup for 2010 Superjet
Bars and steering may tighten it up but you still don't Get the throw like a pre 08 does without a pole and steering cable swap too. My standard RRP steering on my 07 has been great, I'd recommend it.
john zigler
wisconsin
To answer the question "what is the best steering mod for a 2010 SJ" it is my opinion as stated above to change out the pole, and steer cable to either a earlier 96-07, or aftermarket RRP, etc.
Personally I do not like just changing the cable to an earlier one, with a different mount bracket. We HAVE done this here and again IMO is a little sketchy, and not something I want to put my name on.
I do have our own quick steer, steering systems. These are short plates, with bearing mount. Doing this and then drilling and moving the cable in at the steering nozzle is a good cost effective, safe mod that works very well.
Here is my steer system;
RCJS Steer System (watcon.com)
I do also have std length plates, if you wanted that type.
Here is a pic of the steer cable bracket you would need to make, and adapt to your 08-later pole to run a 07-earlier cable. Again, It is MY opinion this is not a good idea.......
