Quinc
Buy a Superjet
- California
Running dual cooling into the exhaust manifold. Is it better to restrict the water coming off the head and pipe, or to restrict it coming into the exhaust manifold?
Those cold fusion pissers are cool but don't offer nearly as much restriction as you'd think. It might be possible to extend the threads to let them close further but I haven't experimented with that yet.
Use the brass seat from a worn needle and seat. You can drill it to any size you need. It will fit perfectly into cooling lines. I keep 2 or 3 different sizes zip tied together for quick change and to keep from losing them.
Use the brass seat from a worn needle and seat. You can drill it to any size you need. It will fit perfectly into cooling li es. I keep 2 or 3 different sizes zip tied together for quick change and to keep from losing them.
I run a B pipe and restrict the flow after the pipe that way it creates a better spray for the pipe.
This is how I have done it forever also. I have sets of 2mm and 3mm that I run in the winter time...I use little SS hose clamps to hold them in place. Works great!
I just run a T on the inbound cooling line to feed both manifold ports. You get almost the same effect of dual cooling by putting water in both ports but you are slowing down the volume a little bit. My sprayer rifles out plenty of water and it's quite nice with how warm it is. Not hot, but very nice and cozy warm![]()
Me too. When your ski is running perfect feel the pipe and cylinders. You will figure out when its to hot or cold.I just go by feel, I feel my motor whenever i have my hood off, so i know what feels about right. I know, that doesn't help you any, but thats just what i do.
