781 Big Bore Power
View attachment 153219View attachment 153220View attachment 153221
These motors RIP hard! I have been running one of these in my surf freak and am stoked with their performance. Blue has been refining the sleeve and porting design on this motor for years now and it is right on the money.
View attachment 153225View attachment 153226View attachment 153227
These beautiful Big Bore motors are newly built 62t/61x (same as RN '96-'11) 781cc freestyle motors ported and built by Blue/JetManiac. They designed to offer the most freestyle low end power for the best big bore value.
62t cases- freestyle big bore ported and epoxied intake and front stator areas, cases bored to accept big bore sleeves
61x cylinder- freestyle big bore ported, new JetManiac custom Big Bore sleeves installed and bored to 84-85.5mm, exhaust/head decked
New Pro-X top end with new pistons, rings, and wrist pin bearings
New US quality gaskets
New rebuilt/SBT crank with 1 year unconditional warranty
(have options for hotrods or new oem cranks also)
New OEM crank seals
New carb jets and springs for oem 38's included, and carb tuning specs included
Cases, cylinders, and bedplates (clearanced for bpipe) are sandblasted and then bead blasted, painted and baked on beautiful semigloss black finish
Video here:
These motor are designed to work well with stock dual 38mm carb setup and jets, springs, and carb tuning specs are included. (Of course, JM BB will work well with larger carb setups like 46's or larger.)
ADA head with custom ADA/JetManiac domes and complete intake/carb setup package also available.
*We can also rebuild your motor into one like this or trade-in your core motor (crank, cases, cylinder) with usable parts for approx. 400. credit off this motor.
Short block $2680.
(Outright purchase with no core required)
Whats the price to take my limited 701 setup up to one of these 780's....? All parts in my current setup are in perfect condition,no send cranckshaft motor is 2008 year old. Thanks for the info. send ARGENTINA ?781 Big Bore Power
New OEM crank seals
Video here:
Short block $2680.
got any pics of my black 781 carter b picked it up awhile back its going in this hull
anyone have any water intrusion issues with there 781 motor?
motor is running stock carbs and airbox and runs ok as long as you don't cut it off more than 30 min or so
step 1 Im flushing the motor on the hose for about 30 seconds, while running and blipping throttle
step 2 running the motor with no water up to 20 seconds, revving it out a couple times to make certain the pipe is dry
at this point it will restart no problem...
after 30min or so of sitting it will not restart at all and the plugs will be wet.
but if I pull the plugs before I try and restart it and dry them off it fires right up.
I have only run the motor thru about 2 tanks and already have scarring in the cylinders
Is it possible for me to send my complete motor and you do the work and tune it and send it back so I can bolt it in and go? If so, how much? Have stock SBT engine with ADA Head and B pipe.BB in stock and ready to ship.
