Decking the 760 cylinder doesnt effect blowdown period which cannot be ignored. Yes it lowers port timing and can help slightly. Lowering the cylinder drops the sleeves further into the intake and transfer cups. It also raises primary compression, adds pumping losses and reduces case volume, not good for low end.
HPE 4 and 5 mil long rod kits lift the cyl up out of the intake and transfer cups substancially, increase crankcase volume, address blowdown period and port timing, the long rod dwells shorter at bdc which improves intake cycle. The list goes on. Basically im saying my 4 and 5 mil kits are not the same as other 5 mil builds you may have ridden.
