I looked into groupk's 845cc mod using 62t or 64x cylinders. They said that you have to use an oem head... Oring heads wont work. But any big bore motors I've ever seen no one ever runs stock heads lol... So what are they talking about? Anyway... I have 61x cylinders, just wondering how big I can go with those cylinders if I bored them, over-size sleeved them and bored the sleeves to the max. I have an ADA girdled head
your answer lies below:
The Jetworks 828cc Super Bore is the biggest stock stroke engine modification available for the 61x cylinder. This is the step above the more traditional 771cc Big Bores, taking the first bore to 88 mm. If you are looking for more of what a 771 is going to give you then this is the modification your looking for. The port timings on the 61x cylinder is more favorable for freestyle/freeride application. No need to upgrade to a 62t or 64x cylinder that will not match your current exhaust set up. Our porting specs give you a very wide and predictable power-band that pulls extremely low but continues to climb well after the mid range. The power-band is not a “light switch” but rather very linear with instant acceleration whenever you want it. There is no waiting for the power-band to hit. 828cc’s, OEM Cylinder, and stock stroke crankshaft, what more do you want?
We recommend that you minimally use our OEM 38mm T.T. Modified Carbs, and for a more aggressive hit use a set of Blackjack 44 or 46 Carburetors.
*Stroker Packages Available in:
+4mm @ 876cc
+6mm @ 901cc
+8mm @ 924cc
The 828cc Big Bore modification includes:
Removal of OEM Sleeves
Custom Sleeves & Installation
Custom Wiseco Pistons
Cylinder Porting & Honing
Cylinder Boring & Counter Bore
Cylinder Decking
Chamfer Of All Ports
Base Gasket & Wrist Pin Bearings
Replacement pistons available in:
88.0mm @ 828cc
88.5mm @ 837cc
89.0mm @ 846cc
Requires use of our girdled Super-Bore cylinder head and domes.
Requires crankcase boring
(Optional crankcase porting offers increased acceleration)
