Black Friday week starts today and continues until Cyber Monday at JetManiac
We will be posting new super deals daily, and sometimes several times a day.
Our annual BOGO sale starts on Wednesday.
Black Friday Deal 1: Solas 9/15 Impeller
Solas 9/15 Concord big hub Yami 144mm impeller $301. -BF sale 199.80
-Impeller includes rubber nose seal and Solas impeller tool.
-Only 3 in stock at this special price
Black Friday Deal 2: Solas Mag Pump
Special purchase! JetManiac was able to buy several Solas mag pumps at very special pricing.
These are brand new pumps that are open box without the Solas packaging, but who cares about a box right?
Solas 144mm 12 vane Stainless MAG Pump stator 579. -Open box Black Friday Sale $399.
*Includes Solas pump cone and Stainless hardware
(these two only)
*Fits all years Yamaha Super Jet and Blaster with use of standard stock length driveshaft.
Black Friday Deal 3: Solas all stainless wear ring
Solas 144mm All stainless wear ring/impeller housing 339. -Open box Black Friday Sale $249.
(this one only)
Black Friday Deal 4:
PHP intake manifold and VForce 3 reeds
PHP (PowerHouse Products) has designed what many (including us at JetManiac) feel is the best designed intake manifold for Yamaha twin carb motors. This is a state of the art freestyle intake manifold for 62t or 64x Yamaha cases, not a manifold designed for the needs of high RPM racing. We have installed and tested them on PHP, DASA, and JetManiac/Blue motors with great results.
This intake was designed specifically for freestyle performance. It features a shorter and better designed intake track shape for more freestyle low end performance. The manifold is a 3 piece design with a removable O-ringed billet carb base plate which makes removing and reinstalling carbs easier while preserving carb linkage alignment. The manifold itself is 2 piece for future compatibilty with longer crankcases cases in development at several companies. Only a longer speed plate will be required. Removable throttle cable bracket is included.
PHP manifold is designed to work best with VForce 3 reeds and cages, but will work with stock, VF2, or other reeds/cages setups. Manifold inlet is a perfect flow fit to the larger sized VF3 reed stuffers.
PHP 3 piece intake manifold -Retail $365. JM Sale price 299.90 **Black Friday special $284.90
(Includes PHP manifold, dual carb speed plate, throttle cable bracket, carb base gaskets and all SS hardware for carbs, plate, and to cases)
VForce 3 reeds/cages system $259. Sale price $219.90 with manifold purchase
(includes reeds with VF3 custom cages and gaskets to motor and to manifold)
Black Friday Deal 5: Green JM billet flywheel cover
Green JM billet flywheel cover $160. Black Friday sale $124.90
(this one only)
Black Friday Deal 6: ADA girdled head kit
ADA girdled head kit complete -reg. 385. -Sale 309.
(includes Silver demo ADA girdled head shell, new girdle kit, 2 new 701/35cc, 760/38cc or other sized domes, orings, hardware)
Optional add:
JM SS allen bling head bolt kit (10 stainless allen bolts/washers) -Reg 25. Sale 15.
Black Friday Deal 7: ADA nongirdled head kit
ADA nongirdled head kit for Yamaha 701/760 300. Sale 249.
(includes ADA nongirdled head shell, 2 new ADA 701/35cc, 760/38cc domes or other your choice, orings, hardware)
Optional Add:
JM SS allen bling head bolt kit(10bolts/washers) Reg 25. Sale 15.
Black Friday Deal 8: XScream 155-165mm billet trim system
XScream 155-165mm billet trim system $999.50 BF sale $789.
(one only at this price-overstock)
Complete system includes:
-XS billet reduction nozzle 91mm
-XS billet trim ring assembly
-XS billet steering nozzle 94mm
-XS upgraded bolts/bushings
-XS trim cable
-XS billet trim cable pump mount
-XS trim lever
-XS billet steering cable end/heim joint
-Stainless hardware
Black Friday Deal 9: Solas 148mm MAG pump
Solas 148mm 12 vane stainless MAG Pump stator 650. -Open box Black Friday Sale $489.
(this one only)
(Includes Solas pump cone and Stainless hardware)
Solas 148mm all stainless wear ring 400. -Open box Black Friday Sale $269.90
(this one only)
Black Friday Deal 10: Skat 155 nonsetback MAG pump
teaser, coming soon
