- Holt MI
Do you need to pull out the motor to remove stock exhaust and install a b-pipe?
Do you guys have any jetting specs for a 1996 with dual carbs running this pipe? I'm at sea level. Thanks.
jetting at sea level is 140 high 70 low and 1.5 n/s with gold 115 spring. high screw 1 turn out low screw 2 turns out. if you have a 72.5 or 75 low jet it will work.
