650/X-2 Blaster factory limited chamber
Anyone interested in a blaster limited chamber. Been away from the scene for awhile so not sure if these are being used anymore or not. I had it in my x2 with a 750 until I put a 701 in it. Has been beat in a little for it to fit in a x2. $250 shippedimage.jpegimage.jpeg
What did you use for a headpipe? I May need that chamber you have. I have an 89 with a 750/800 rebuild in progress right now......
Do you have any interest in trading even up for a mariner ? I'm not sure what I'm going to do yet; just wondering........
Above you spoke about a 650 exhaust manifold, and have pictures of the chamber. But you've made no mention of a head pipe. What did you use for the head pipe from the manifold to the chamber?
With this pipe 750 big pin bottom end, small pin cylinders, sxr carbs, sxr impeller it ran really good. Would run with a sxr if not a little faster. Was a pretty unstable ride at that speed.
