blaster rear waterbox advice
Does anyone have any info on doing the rear waterbox conversion? I have a 95 raider waterbox, will that fit? How did you guys mount it? Im doing the carter b rear chop so I should have plenty of access.
Talk to carter about fitment with the rear chop. There should be enough room, you can glass in inserts to run rubber straps while you have the back open.
In stock skis I have drilled through from the ride plate area and run a bolt through that held an SJ style tank strap mount to use the SJ tank strap. It worked well but was a PITA to get it set up or when trying to remove the box (but, once you get it mounted, you wont need to move it often, if at all).
iowa
Does this conversion put the exhaust out the left or right side. I currently have a 701 Ind rear exhaust out the left side.
