- Ohio
In the begining of the season my blaster was running poor( bogging on takeoff,sounded like a rev limiter but then would wake up but lose power off and on). Now it does about the same thing,you can rev it on the trailer a few times and it sounds good but all of a sudden it backfires and breaks up and takes longer to gain rpms then all of a sudden it revs normal once or twice then back to breaking up and backfiring. When it is in the water it will idle fine but when you hit the throttle it bogs or cuts out and has a lack of power. I have tried a different long block motor, 2 stators, 3 CDI boxes, 2 carbs,and 2 coils but no difference. I have also disconnected the kill switch but no difference,as well as a couple different plug caps and 3 sets of new plugs. After riding it,the plugs look good. This Blaster ran good last year but not this year. I have pretty much ruled out carb issues because I took the carb and threw it on my 61X Superjet and it ran perfect,and swapped the Superjut carb onto the Blaster and it didn't make a difference. I'm at a loss as to what else it could be.
