hey im redoing my blaster and i jus tput new umi handle bars on it, but theres this big ugly silver plate on the handle bar stand. does anyone know if they make a part that attaches on or do most people cut it off.
Just cut it off. Thats where the stock handlebar cover actually mounts to, but with your aftermarket handlebars/pad you don't need it so you can cut off the brackets.
Try and find yourself a UMI Steering system. That looks the best and feels the best.:biggthumpup:
if you can find a spot to drop in, diamond beach all the way at the bottom of wildwood in wildwood crest always has real good break, at least it has every time i rode there.
:hail: ME too was little AWOL last year due to moving and other stuff that came up but that is my normal spot. We ride out of the BL end, there is a pretty good size group. BLFreeride.com
I reccomend some good moto bars. Renthal, Tag, or Pro Taper. You will be suprised how much better a wider bar feels. I'm also a little taller, so I run a riser with some tall bend Pro Tapers, much easier on your back.
