Super Jet Blew my hood off. Almost blew my head off. Stripped every head bolt.
CA
Already did, thanks! :p
Jesus! There were that many fumes? I would have never thought engine bay explosions on these things were a "thing". The sound it made was awful. Like PFOOOMP! would be a good descriptive word. I'm kinda glad the hood flew off, who knows what else could have happened if the strap held.
I've seen it happen on a stock rn. Gas had been sittin in the hull for a while, the guy turned on the bilge before riding. BOOM. The hood blew off and put several large cracks straight through the middle of the fiberglass of the hood. He ended up using about 50 zipties to hold it together so he could ride for the weekend!
hhh
A friend had a wammer hull busted up pretty good because of fumes and a bilge wire shorted out. Hood was ok and the hull sides to the beating if I remember correctly.
sharkcus
Breakin' the atmosphere.
Strongsville, OH
So was it the head hitting the hood that took the hood off or was it a combustion inside the hull
It was the combustion (fireball). I don't think the head physically left the motor, just lifted up lots.
What it looked like right after the lake
Obviously, the stator side cyl had the problem
Head. The clean one is the stator cyl. The head is still in good shape.
Good (rear) plug
Stator side plug (that lifted)
Cyl looks to have survived intact.
sharkcus
Strongsville, OH
Hmmmm. Swapped plugs with another ski awhile back, didn't even dawn on me they might not be the ES. Ooops. But as mentioned, that wouldn't have caused this. They have been in there for at least 2 prior rides. What I did notice is that my head bolts didn't go that far into the holes. Only about half way. These were stock head bolts from a 650. I wonder if this head is thicker than stock.
Edit: Just thought of something. Having the non ES plug would lower your compression a bit, wouldn't it? I wonder if it would be noticeable.
Ohio
Yes a AM head is thicker than a stocker and would require longer bolts ( I think, right????). I think you just solved your problem! It has to be that!
I have heard of people running shorter pulgs with no issue and no noticable performance loss..
Wow you definately ignited fumes in the hull. Kawis have a cap on top that is press fitted in, instead of blowing up the hood it will blow the cap. If I had to speculate, i'd say the head was loose when you were riding and unburnt fuel was leaking into your bilge. You may not have noticed; I've seen engines run flawlessly with serious issues happening. I would take a good look to make sure battery/starter/bilge or any electrical connections are tight and clean to be on the safe side.
Proformance1
Liquid Insanity
Vendor Account
New York Crew
You should always check every part you change, for installed length. Plugs, bolts, etc and should use loctite or similar for head bolts. Think about short bolts and a short spark plug. Add in some detonation and the bolts back right out.
sharkcus
Strongsville, OH
I didn't have a chance to measure the thickness, but that **HAS** to be the problem. The more I looked at these bolts...they could have gone a LOT lower into the head.
